Turn by Turn map zoom question.
Hello all,
I'm wandering if it's possible to disable or change the amount of zoom when navigating on the Edge 1030.
When I'm riding I use a datafield screen and when arriving to a crossroad or turn the Edge switches to a verry verry detailed map. Often when taking crossroads it's states that I need to turn right and directly after that take left turn when in reality it's just straight forward.
So if only when a turn by turn prompt comes up I would like to have it fully disabled or just a zoomed OUT view of the map.
I can't find the option for it.
Thank you!
Edit: You can see an example here: https://imgur.com/1ozN8FJ
    0 Former Member over 5 years ago in reply to gABBY025
    There are lots of problems with the latest OSM update. In my hometown area they have added parallel "Bike Trails/Lanes" to many of the main roads. This is driving my Edge crazy. It tells me to get off the street (which is eminently bikeable) to get on the parallel trail (which does not exist) that is 3 feet over. It does not matter where or how the route is created. The OSM map layer is flawed, and will drive the routing engine of Edge nuts.
    The only way around it would be for the current Edge software to have an "Avoid Bike Trails" option for routing, but that does not exist
    Ted in Providence, RI - where almost every major city road, has two phantom bike lanes (one for each direction)
    "You gets what you pay for, when it's free" - OSM
