Firmware 7.20 update & Vector 3 problems
After the update to 7.20 by edget stopped working with my Vector 3. Removed and added, no luck. Resetted the whole devices, added them successfully but not even if connected the Edge is not registering any signals from the Vector 3.
The Vectors work just fine on the iphone.
Any hints on what might be the problem, or anyone else with the same problem?
  • v7.20 and vector 3 together worked well for me
  • Thanks Loukas, did you have constant connection for longer ride or did you just had a test? It connects short periods of time and disconnects again for me. I have about 1-2 minutes connection. Having resetted both the 1030 and Vector 3.
    So far, 4 TrainerRoad rides (1 to 2 hour sessions) and the 1030 works the same as previous firmware. Vector 3 kept constant connection as did my HRM and cadence/speed sensor.
  • After the update to 7.20 by edget stopped working with my Vector 3. Removed and added, no luck. Resetted the whole devices, added them successfully but not even if connected the Edge is not registering any signals from the Vector 3.
    I have no problems with my Vector 3 running 7.2
  • Might be worth ascertaining if people are using Bluetooth or ANT, the problem might just be with one of these.
  • Thank you all for your feedback. I am using ANT with still having problems. will probabaly contact the support to get it fixed. Might be that the 1030 or the pedals have an issue.
  • Shahramk - If the Vector 3 pedals are actively paired with your iPhone, the Edge might have a problem finding the pedals. I would recommend removing the pedals from the iPhone and the Edge (if listed) and try your search again. If this does not work, I would reach out to Garmin Support for additional assistance.
  • I’m having the same problem. After the update, Vector 3 pedals stopped working properly via ANT+. They are detected and connected if I force the connection, but after a few seconds disconnect again. After removing from Edge 1030, I discovered that I could use them via BLE. After 5 hours ride, no disconnection, but if I try again connect them via ANT+, again the connection only lasts for a few seconds.
