Light Network on Edge 1030
I recently upgraded to V7.00 on the Edge and 3.50 on the Varia RTL 510. I am no longer able to set up my light network. I also have a Bontrager ION PRO RT headlight. Radar works, but the Edge doesn't see the lights. I tried removing them from the network, but am not able to add them back. Has anyone found a way around this ?
Remove the RTL 510 from your Edge1030 and then add it back by searching for ALL new devices. It will find the radar and the lights. If you just add the radar then the light function will not be found.
This happen when it pairs with Edge as a Radar but not as a light. It needs to pair as both type of devices, Radar and Light. Unpair it and pair it again making sure you search for all type of devices.
I had a 1030 and UT800 which paired and worked as advertised. But then the 1030 got replaced with a refurbed unit and it won't recognize or pair with the light (either searching for "all" devices or searching specifically for a light). I don't have radar and nothing else is paired except Di2 and cadence. So I can't unpair it as it doesn't show to be paired. The 1030 has all the updates that Garmin has pushed to it, AFAIK.
