Hi there,
Before of anything, english is not my mother tonge so sorry for if it is not very clear explained.
Just write here to ask if someone is having the same problem like i got with the sensors paired with the bluetooth protocol.
The issue consist in when you go far from the computer, or you made an stop and suspend the device, when you try to resume the activity all ant sensors pair again but the bluetooth ones do not. I realice that with the powermeter (quarq), that was initial with bluetooth and since I change it to ant no problem... but the heart rate band is on bluetooth (polar) and got the problem that when I stop or pause the sesion, the band do not pair again, and can not chage the protocol like I did with the power meter, and the only way to fix it is to stop the session, tun off the device and turn it on again, that is a weird procedure.
Regards everyone.
