1030 V6.3 Doesn't actually turn off
Hi - found my unit doesn't actually power down when I tell it to. It has the appearance of powering down but come the next day it is flat. I have also noted that sometimes it turns itself back on. Has anyone else noticed this?
  • Have you actually powered it off or just put it in sleep mode? I find that in sleep mode that the unit continues to use power. I always make sure it is turned completely off. If I plan to be off the bike for just a few hours, I'll use the sleep mode.
  • I hold the power button and when the choice of "Sleep" or "Power Off" appears, I press "Power Off".
  • Hi - found my unit doesn't actually power down when I tell it to. It has the appearance of powering down but come the next day it is flat. I have also noted that sometimes it turns itself back on. Has anyone else noticed this?
    it happens to me as well.... sometimes too.... and that unpredictability drives me nuts :mad:
    Sometimes happens to me. Not very often though. Not a big deal to me.
  • I know mine failed to sleep once when I left it on the Strava Connect IQ app. Otherwise it goes to sleep fine. I do occasionally power off because of the battery indicator bug where it stays on 100% if you suspend/resume.
