I’ve been trying to get my sensor setups how I want them to be and am not having much luck getting things to play together nicely.
I want my indoor ride data files to lack speed/distance data, but the Kickr Snap sends speed & distance data in the power stream and there’s no way to disable this.
I reinstalled my Quarq and connected the Garmin to the it as the power source, but today’s test run didn’t have working erg resistance. I did disable the Kickr power & speed sensor entries, but the “indoor trainer” menu did still list the Kickr as the trainer sensor, presumably through ant-fe so I expect erg to still work while taking the power data from the Quarq rather than Kickr.
During the ride, I could feel resistance changing but it wasn’t effective at all, power numbers were drifting around as if outdoors without erg.
I reconnected the Kickr power sensor and erg started working again, but the speed/distance data reappeared so no-go and I assume at that point it was reading power from the Kickr instead of Quarq.
Will the Garmin not work to read power data from a power meter while erg controlling the Kickr? I’m at a loss as to why it didn’t work as expected.
