Elevation Screen Zoom and Pan
Is there a way of zooming and planning the elevation data screen during a ride? I'd like to be able to zoom out and see more of the ride or pan sideways to see earlier parts of the ride. The manual doesn't say anything and randomly tapping and swiping on the screen also doesn't seem to work. Is this possible! Thanks.
  • Panning the elevation screen is not possible, but you can zoom in and out:
    Tap and hold either onto the heigth or distance scale until <+> and <-> appears.
  • Panning is only possible in the elevation screen of saved courses under the 'where to' menu. You can also zoom & tap a point on the profile to give you a spot height and distance. If you know how far you've already travelled you can then pan & see what's ahead. I've used it quite a bit & can be done whilst navigating. Unfortunately the same can't be done on the elevation datascreen
  • Tapping the scales works! Thanks. I never would have guessed. I wish they would write some of this down in the manual.
