Map & TBT display Issue
I got my Edge 1030 about 2 weeks ago and update the firmware, software and map to the latest versions (no betas). I tested out a TCX route today that I created on RideWithGPS. I have the data screen set up for 10 fields. Text displays on the data screen at 0.1 miles and then again around 150ft before the turns. The MAP, however, does not display as I think it should as I've read in some posts. What am I missing here, what did I forget to enable to have the MAP with the TBT display during the turns and then return to the data screen? My Garmin Edge 800 use to work like this and the 1030 apparently does also. Tanks for your help in advance
