Turn by turn not working
Turn by turn popup, next point, and distance to next not working when navigating a course since firmware 6.30. What is different? The cue sheet screen showing the next turns and distances does work.
  • On mine it works fine as long as I never leave the course. If I get of course and back on course, then the navigation can get lost and stop giving directions (but not every time). The distance to end and to next remain fine, and the guide screen with all the waypoints is accurate. However turn-by-turn is lost. To get it back on track, I stop the course and start it again - then it finds that I am on the course and it works from there. That is until I get off course again...
  • I downloaded firmware 6.43 today, installed, and tested it. 6.43 seems to have solved the issue. The pop up map occurred 0.11 mile prior to the turns and the next point and distance to next worked.
  • JimPurdy We are glad to hear that this has resolved your issue. We will close out your support email interaction that is related to this as well.
    Any other users seeing this symptom should download and install the beta (Sticky in this forum) if they are comfortable with that, otherwise this next production release should resolve this.
