I've had this issue for weeks. I had tried different cables without success. Read this thread. Inspected the connection pins in my Garmin but did not see anything out of the ordinary. Tried the "…
I tried resets, I tried different usb cables, I tried different laptops, I have tried the procedure which I have found in the internet (disconnect, power off, push lap/rest button, reconnect to laptop) all without success. Any idea what to do apart from sending it back ?
Try this procedure. I found it in this forum awhile ago.
"Try getting the unit in to mass storage mode by plugging the unit into the usb port. Press and hold lap/reset while pressing the power button for about 5 seconds. The screen will go blank – let up on the power button at that time but keep holding lap/reset. This should force it to mass storage."
I've had this issue for weeks. I had tried different cables without success. Read this thread. Inspected the connection pins in my Garmin but did not see anything out of the ordinary. Tried the "Press and hold lap/reset while pressing the power button for about 5 seconds" suggestion and that didn't work either. Finally, based on this comment "Some USB cables only deliver charging which might explain the problem", I decided to make sure the usb cable I was using worked for data transfer so I used a cable from my kindle. It worked, yeah. Thank you all. :-)
Same problem here. With Software 7.50 as well as 7.87. Can force it with Lap button into this mode, but does not go allone
