Cannot Bluetooth connect iPhone X 12.0.1 to Garmin 1030 v6.3
Argh. This is so aggravating. Worked fine in 6.0, but now I've lost my phone connectivity I tried the DC Rainmaker suggestion to wipe the connect.
When I try to restart here is what I get:
1. In the `Select An Accessory menu`, I see `BT_Edge 1030` and then when I click on it, I get the pair request message from both the phone and the 1030
2. However when I click check on the 1030 and pair on the other, then neither side changes. I still see the "waiting for phone" message on the Garmin side and I see the Retry message saying it couldn't connect and to forgot the 1030 and try again.
3. When I choose exit for the Garmin side, it shows that there is a Smartphone connected and the iPhone in the Bluetooth setup shows that the the is there is a BT_Edge connection so I wonder if there is something wrong with Garmin Mobile Connect.
This just loops. Has anyone gotten this to work? I see one note which says the answer is to factory reset the Garmin, is that the only answer?
