Problem to add Connect IQ datafields
im trying to add some Connect IQ datafields that i have installed, i can add 2 fields but after that i cant add them to the datascreen its simply adds a timefield instead
the counter for Connect IQ datafiels reports that im using 2/10 fields. anyoneelse with same problem?
i create i new screen and selects 5 different Connect IQ fields and its ands up with 2 IQ datafields and 3 timefields.....
  • Try to set the 3 missing IQ fields in the direct way - not via setup trainings pages:
    From the homescreen tap on your activity (road, mountainbike...) and swipe to your IQ-screen.
    Now press and hold the finger on the first time-field until it gets black.
    Then chose the desired IQ-field.
    If it works, do the same for the others.
    (of course it is necessary that the IQs can be set on small datafields...)
    Yes, I have exactly the same problem, except in my case I am limited to one IQ data field. Try to add a second one and I get the time field. This is with FW 6.00. There's a bug there somewhere.
    This doesn't work. You can select the IQ field to replace the outlined field, but what you get is the Time field. I can place the first IQ field on a screen with your suggestion, but with the second, I always get the Time field instead.
    thats not working, same problem i got the time field instead.... FW6.00
  • Yes, I have exactly the same problem, except in my case I am limited to one IQ data field. Try to add a second one and I get the time field. This is with FW 6.00. There's a bug there somewhere.
    i was also limited to one IQ datafield at first, but somehow after a while i luckely now can have 2 IQ fields..... must be something with FW 6.00
  • I was able to set 4 IQs to one screen (by direct method, FW 6.0) without any problems.
    3 different IQs and one of them double...
    After i had removed some IQ apps its working for me too!
