No Vector3 Calibration Notification
Since the latest firmware update (maybe the one before) I do not get any Calibration Notifications anymore when riding with my Vector3. I see power sensor 999999 found in the screen. but to calibrate I have to manually go into the sensors section, select the pedals and select calibrate.
I used to get automatic notifications to calibrate without problems up until a couple of weeks ago. The setting for calibration notifications is switched on.
I also think I do not get any Low Power notifications for the battery status anymore, but as I should get these only once every 30 rides or so I cannot tell wether this is true.
  • Yes, I noticed the same thing on my recently bought Vector 3 pedals, it worked on the first ride and on the second ride it no longer asked me to calibrate. I had to go into the power meter settings to do it manually.
    I have the calibration notification turned on in the power meter settings so it should work.
    for me it works as before!
    what Connection you use? ANT+ and BLT?
    i only user ANT+ and disabled BLT
  • I often have the same issues with auto-prompt "Calibration".
    Sometimes I'm asked other times not.
    One hint here: If you're not asked to calibrate, then drop down screen, choose right screen 1 or 2 times, then you can choose calibrate from here.
