New Public Beta 5.27 Now Available
A new Beta software for the Edge 1030 has been released. Full change log, instructions, and software for installing the beta can be found here.
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
[h=4]Changes made from version 5.00 to 5.27:[/h]
  • New Feature: Added Connect IQ 3.0 support.
  • New Feature: Added Shimano STEPS sensor support.
  • New Beta Feature: Added extended display mode support. Select Menu > Extended Display Mode to allow the Edge device to act as an extended view of a supported Garmin multisport watch's data fields during a multi-stage activity such as a triathlon. Follow the on-screen Edge and multisport instructions to get started.
  • Improved sensor searching flow.
  • Fixed issue causing unexpected u-turn sharp bend warnings.
  • Fixed issues preventing device-to-device transfers from completing and made improvements to the connection flow.
  • Fixed various issues with the Varia Vision.
  • Fixed issue with Physio TrueUp duplicate activity detection.
  • Fixed issue where VO2 max could be corrupted.
  • Fixed issue that could cause the device to crash while connected to the phone.
  • Fixed bike light beam angle and light mode data field text.
  • Fixed the Follow a Course flow for indoor trainer mode.
  • Fixed issue with the device where going into mass storage from a power off state may cause Garmin Express to offer a map update that the device does not need.
  • Improved Physio TrueUp responsiveness by syncing with the phone after powering up or resuming from suspend.
[h=2]Installation Instructions[/h]
  • Connect your Edge 1030 device to your computer using the micro-USB cable.
  • Download and unzip Edge1030_527Beta.zip and place the GUPDATE.gcd file in the \Garmin folder of your device's internal storage drive.
  • Disconnect your device from the computer, approve the update on the Edge, and wait for the update to finish.
  • If you would like to revert to the last public release software, follow the above steps but place the GUPDATE-500.GCD file in the \Garmin folder. Rename the file to GUPDATE.GCD before disconnecting your device.
    NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
