Hi all,
I currently own an Edge 810, been using it for almost 5 years now.
Because of broken silicon on/off button I'm thinking of moving to a newer model Garmin. Maybe the new Edge Explore or the more expensive Edge 1030.
An issue with the Edge 810 is troublesome recalculating after a route deviation.
As I understand the Edge 1030 has different navigation software, maybe it's better now with the 1030. Hope someone can verify this.
So, how does the 1030 recalculate a deviation when using it to calculate a route from starting point A to endpoint B?
No preloaded course! The 1030 does a fresh on the device calculated route.
How does the 1030 recalculate when deviating from this route?
Option A. Does it recalculate an alternative route directly to endpoint B? Same like car navigation.
Option B. Does it try to bring you back to original calculated route or bring you back to the point where you deviated from the original route?
Option B is what my 810 does and that really is bad.
So, I hope the 1030 now works like option A.
Someone experience with this?
