Compatible IQ apps show as "Not compatible"
Not sure if this problem should go here or in the Garmin Express forum. I just received a replacement 1030 (had the blue halo screen problem on the previous unit). I've tried to sync the same five IQ apps that I had on the previous unit to this replacement one: AppBuilder, AppBuilder2, gimporter, hGradeMax, and hAltMax. When I sync in Garmin Express, after a while I get an error dialog saying "Some files could not be sent to your device. AppBuilder (Not Compatible). hAltMax (Not Compatible)." They're both shown as being compatible with the 1030 in the Connect IQ Store, they both worked fine on my previous 1030, and AppBuilder2 (which is the same app as AppBuilder but with a different name so that one can use two different formulas in two different AppBuilder data fields) installed without any problem. Whatever the problem is, I don't think that it's due to the reason that is being offered.
Same for me..Apps that use to work cannot be updated (Trailforks for example). I tried to uninstall and reinstall but now I can't install it again due to compatibility issue. Same thing for other widgets.
