Garmin sensors are too sensitive to type of road etc. I bought Wahoo. Not problem at all. They are far superior and they communicate with my Garmin 1030.
Same issue. called customer support. after chatting a while, the rep reveals this is a common complain and that there is no fix for it.... Think I;ll go back to the old magnet sensor. This magnetomer based…
Great advise! I recently bought a STAC zero and it happened on time that the chain got catched by the very strong magnets that thing uses to create resistance. That must be the reason. Can't wait to verify!
I have seen this once or twice since 5.0. And it only lasted for 10-20 seconds or so each time, that I noticed. I was going 17mph and the speed would go down to 6-8mph. I have my speed sensor around my front hub. It is the garmin no magnet sensor. I never had any issues before 5.0. It may have just been a fluke. 5.0 has been relatively pretty good for me so far.
I have a similar issue
I ride in Fulshear TX and I found that several other Garmin owners have also the same issue
I have a 1030, I use the sensor from Garmin in the back wheel. I have used in the front wheel and had the same issue.
we can clearly see where the speed goes crazy ( 10km/h 40km/h and then 23km/h in one second). It is clear that while we ride in a new concrete road it causes the issue. It may be because of the iron inside the concrete . I’m wondering if I get a Wahoo sensor it could fix this issue. By the way I use Wahoo cadence sensor and I do not see any kind of measurement problem.
I think its the new speed sensor that has the issue. It seems like most of us with the hub-style speed sensor show erratic speeds when going across metal bridges and roads reinforced with a lot of rebar in the concrete. I never recall having a problem with the spoke-magnet style sensor. I have the same problem on the stretch of road as 6228927 mentioned.
Recently started with Garmin and a Fenix 6X and a Speed Sensor v2 in Singapore. Started seeing massive speed spikes and a few drops outs.
Tried a reset and reconnect and the same issue.
Like others on here and other forums Im seeing these in similar places so it must be due to interference somehow. Disappointed considering the cost of them.
