Since beta 4.24, now on 4.36, when trying to view a ride, selecting History > Rides, edge 1030 freezes. I have to reset the device holding power button for 10 seconds.
Any idea? Any solution?
I have moved the contents to my pc. Without any data on the internal storage activities folder, I can see the activities stored on the sd card (from my old edge 1000). Now, when I copy one or more fit activities files to the activity folder, I can't see any "new" data when going to History > Rides (except the old ones from the sd card), and when reconnecting the edge to my computer the file or files copied had dissapeared. Unbelieveble!!
Is the 1030 configured to use the SD card for activity storage?
Hi, How are you restoring your history? Do you put it in the Activities folder or the NewFiles folder?
I restore my history by putting them in the NewFiles folder. They take a while to process if you have many files
Also how many activity files do you have in total between the device & memory card?
There is a 200 Activity total limit on the device/card. Following a firmware update or file restoration, on startup I found that Activities are processed in reverse order ie oldest first. If you have more than 200 activities it deletes from 200 onward ie your newest files.
The weird thing is this only happens following a firmware update or restoration. I found I could still record activities above the 200 limit and they would be visible on the device
