Configuring Fly6 to turn on but without flashing
I recently bought a Fly6 and I am struggling to understand how the Garmin Sensor settings and the Fly6 settings work together, or if they don't, how I can achieve what I am trying to.
I already have front and rear dynamo hub powered lights so I want to use the Fly6 as a camera only and not have it flash so I can get more recording time between recharges. In the Cycliq Pro iPhone app, I configured the light modes to disable all modes except "Off" mode.
In the sensor settings on my Edge 1030, I see the light and it is enabled and under Network Options->Light Beam Activated I've set to Timer Start. This seems to be working. When I start an activity, the Edge 1030 turns on the Fly6 and starts recording. When I end and save the activity or turn the 1030 off, it stops recording on the Fly6.
Under Network Options->Light Mode there are options for Auto, High Visibility, Trail, Individual. What do those mean? I can't find any description of them in Garmin user manuals or here in the forums. How do they relate to the Light Modes
  • The options you are reffering to are described here: https://www8.garmin.com/manuals/webhelp/variaut/EN-US/GUID-73B08487-BA57-4EF0-A253-D226E229BC68.html
    But that's Varia UT800 light from Garmin, not the Fly6 options.
    The Fly6 CE has different settings (own), see here: https://support.cycliq.com/support/solutions/articles/13000046636-connecting-to-your-fly6-ce-via-ant-
    Helps?
