Shut Downs during an Activity
We appreciate the passion and feedback that the community has been providing. We will be rolling software 4.00 over the next few days and I have listed an advanced preview of the items addressed below.
In addition, we have more updates planned in the near future and are looking for specific feedback in regard to the Edge 1030 shutting down during an activity. I will accept all of the current logs that you may have and would greatly appreciate any logs that you can collect with the 4.00 version. The feedback that we are looking for would include the following:
  • Link to the activity (if available)
  • Most recent error log (Garmin Folder>Debugging>Saved>Most recent err_log_#.txt)
  • An approximate time when the shutdown occurred, the more specific the better
  • Any details about the ride before the shutdown (started a segment, turn prompt, ect.)
If you would like to email versus posting please email the information to directly to our Product Support teams with the subject line of Edge 1030 Forum Feedback
Improvements with 4.00 – this will be rolling out over the next two days.
  • Added enhanced support for Varia RTL510 radar tail light.
  • Updated touchscreen firmware to 85.11 to fix responsiveness in low temperatures.
  • Added CIQ 2.4.4 support.
  • Improved device stability.
  • Added the ability to discard the current ride at any time. This requires several interactions to avoid accidental discards.
  • Fixed text conversion issues.
  • Fixed issues with the Varia Vision data screen setup causing the Edge and Varia vision to be out of sync.
  • Fixed issue preventing a BLE sensor from being added if it was the first sensor.
  • Fixed issue where the ANT generic channel used by CIQ data fields would not reconnect when the device resumes from sleep.
  • Fixed issue where searching for a long address would not provide a proper result.
  • Fixed issue where battery save mode would turn on GPS in the Indoor activity profile.
  • Fixed issue preventing some iPhones from staying connected during the pairing process.
  • Fixed issue preventing activity uploads after saving a ride.
  • Fixed issue where the ascent remaining and ascent to next course point data field values did not match the total ascent for the course.
  • Fixed various issues with sharp bend warnings.
  • Fixed issue where FTP would be reset after recording an activity with a CIQ app.
  • Fixed issue preventing battery save mode if the timer is auto-paused.
  • Fixed issue where calories would be incorrectly calculated for BLE power meters.
  • Fixed navigation audio prompts.
  • I got a twofer tonight, my Edge 1030 shutdown twice during the same ride:
    https://connect.garmin.com/modern/activity/2779773409
    (My Garmin Connect is private by default. If you can't see this activity, PM me your ID and I'll add you to my Connections, or I can email you the .FIT file.)
    Other details:
    Firmware version 5.0.0.
    The 1030 shutdown first occurred between 0:56 and 3:42, the second shutdown occurred between 7:26 to 10:48.
    At the time of the shutdown, the 1030 was displaying data screen #1, no ConnectIQ fields displayed.
    No active Strava segments at that time.
    Not following a course.
    Connected data sensors: Scosche Rhythm+ HR, Bontrager DuoTrap speed/cadence (all connected via ANT+).
    Connected light network: Bontrager Ion 800 RT and Flare RT, with the Bontrager Light Control ConnectIQ data field.
    Other ConnectIQ apps on the 1030: AccuWeather MinuteCast widget and Strava Routes app (neither was active when the shutdown occurred).
    Paired to an iPhone 7.
  • This morning was the third time in the past 12 hours that the Edge 1030 has shutdown, at this point the word "unexpected" seems to be a misnomer:
    https://connect.garmin.com/modern/activity/2780971291
    For the record, it shutdown at 3:25, back online at 6:06.
    All the rest is the same: No active Strava segments, not following a course, Scosche Rhythm+ HR, Bontrager DuoTrap speed/cadence, Bontrager Ion 800 RT/Flare RT (all connected via ANT+)...
    I'm beyond disgusted with this thing.
  • I've had it. This thing is a lemon. I have now had four shutdowns over three of the past four rides (all this weekend).
    Who do I contact for a replacement or a refund?
    Assuming anyone is still looking at the crash reports:
    https://connect.garmin.com/modern/activity/2783788205
    Shutdown at 38:21, and came back online at 40:01 after a manual restart.
    Firmware version 5.0.0, all of the rest is the same as before: No active Strava segments, not following a course, Scosche Rhythm+ HR, Bontrager DuoTrap speed/cadence, Bontrager Ion 800 RT/Flare RT (all connected via ANT+)...
    So having posted numerous shutdowns and other problems, I did a master reset and then DIDN’T connect to my iPhone (IOS 11). I did the setup of pages and everything else and then connected to our home Wi-Fi last of all. No shutdowns or misbehaviour at all, so I conclude it’s related to IOS 11 on my iPhone. So it’s all good (except I get none of the functions linked to my phone, or my Strava account or my Garmin Connect account). As I have written before, one expects more for AU$700.
    On a separate note, does anyone have an answer for why the gear combo numbers comes and goes on the display - i.e. they go from 36/18 to —/—? Thanks
  • 6/30: https://connect.garmin.com/modern/activity/2816745783
    "RTL Error Number":"6E5D8017",
    "Error Message":"......TSKgarmin-ostsk_malloc_mmu.c 2190, Invalid next memory block pointer. rtrn=0x00117B91, mblk=0xC04CE4F0, next_mblk=0x00000000"
    7/01: https://connect.garmin.com/modern/activity/2819755167
    "RTL Error Number":"6E5D8024",
    "Error Message":"Data abort, system r0-15 + cpsr"
    7/04: https://connect.garmin.com/modern/activity/2827128997
    "Error Message":"......TSKgarmin-ostsk_malloc_mmu.c 2190, Invalid next memory block pointer. rtrn=0x00117B91, mblk=0xC095BBE8, next_mblk=0x00000000"
    My 1030 keeps shutting down during activity. I am on Version 5.0.0.
    Per this thread I am sending you the err logs via email but here is one.
    "unit_id":"3960722526",
    "product_name":"Edge 1030",
    "software_part_number":"006-B2713-00",
    "ms_since_epoch":1530376568000,
    "system_version":"4.00",
    "build_type":"PRODUCTION",
    "backtrace":"mtk_stp_btm - Error type ( 1 ) err( 6E5D8015 )",
    "error_cause":"RTL Trap",
    "proprietary_info":{
    "Commit ID":"6125f14575760fccdbd149598eb33956cdab4f3b",
    "Time":"2018-6-30 9:36:8",
    "CDP_LOG":"47D21D,1D74F1,20312D,20312D,2D9B15,20312D,20312D,20312D,2D9B15,361FD5,1D737D,20312D,1D737D,20312D,17B065,20312D,20312D,163C21,47B695,223D79,4842B1,47DC8D,22D031,",
    "RTL Error Number":"6E5D8015",
    "Error Message":"Uninitialized cond var, r0=task ID, r1=cond",
    "Task Name":"mtk_stp_btm",
    "Saved SP":"DFFDEDE0",
    "Saved LR":"00114F6F",
    "Saved PC":"00394612",
    "R[0]":"6E5D8015",
    "R[1]":"DFFDEF68",
    "R[2]":"0252B934",
    "R[3]":"00000000",
    "R[4]":"00000000",
    "R[5]":"00000000",
    "R[6]":"00000000",
    "R[7]":"00000000",
    "R[8]":"00000000",
    "R[9]":"00000000",
    "R[10]":"00000000",
    "R[11]":"00000000",
    "R[12]":"00000000",
    "R[13]":"00000000",
    "R[14]":"00000000",
    "R[15]":"00000000",
    "cpsr":"00000000"
    "ms_since_epoch":1530726192000,
    "backtrace":" - Error type ( 8 ) err( 8 )",
    "error_cause":"8",
    "Time":"2018-7-4 10:43:12",
    "Task ID":"0",
    "Task Name":"",
    "R[0]":"00000000",
    "R[1]":"00000000",
    "R[2]":"00000000",
    "R[3]":"00000000",
    "R[4]":"00000000",
    "R[5]":"00000000",
    "R[6]":"00000000",
    "R[7]":"00000000",
    "R[8]":"00000000",
    "R[9]":"00000000",
    "R[10]":"00000000",
    "R[11]":"00000000",
    "R[12]":"00000000",
    "R[13]":"00000000",
    "R[14]":"00000000",
    "R[15]":"00000000",
    "cpsr":"00000000"
    "ms_since_epoch":1530792934000,
    "backtrace":"
    Function Address: 0x00113B82
    Call Address at Function: 0x00113C96
    Function Address: 0x0025076C
    Call Address at Function: 0x00250780
    Function Address: 0x00239644
    Call Address at Function: 0x00239656
    Function Address: 0x0044F81C
    Call Address at Function: 0x0044F824
    Function Address: 0x0022F6E4
    Call Address at Function: 0x0022F70A
    Function Address: 0x00223964
    Call Address at Function: 0x00223998
    Function Address: 0x0049B6F4
    Call Address at Function: 0x0049B728
    Function Address: 0x004890D4
    Call Address at Function: 0x004890EE
    Function Address: 0x0048E12C
    Call Address at Function: 0x0048E204
    Function Address: 0x001E50D0
    Call Address at Function: 0x001E5158
    Function Address: 0x00313C36
    Call Address at Function: 0x00313C7A
    Function Address: 0x0039DAD0
    Call Address at Function: 0x0039DB50
    Function Address: 0x00749E14
    Call Address at Function: 0x00749ED6
    Function Address: 0x002C11B0
    Call Address at Function: 0x002C11BC
    "Time":"2018-7-5 5:15:34",
    "CDP_LOG":"47D21D,1D74F1,1D5911,1A6B39,1A6B09,1A6B39,1D5911,1D74F1,1D5911,1A6B39,1A6B09,1A6B39,1D5911,1A6B39,1A6B09,1A6B39,1D5911,1D74F1,1D5911,1A6B39,1A6B09,1A6B39,1D5911,1D74F1,20312D,2D9B15,361FD5,1D737D,20312D,17B065,20312D,20312D,2D9B15,20312D,",
    "Error Message":"Data abort, system r0-15 + cpsr",
    "Task Name":"sync_segments_begin",
    "Saved SP":"02454380",
    "Saved LR":"00250781",
    "Saved PC":"00113C96",
    "R[0]":"6E5D8024",
    "R[1]":"00000000",
    "R[2]":"B125012A",
    "R[3]":"C08B002C",
    "R[4]":"C08B002C",
    "R[5]":"02569F20",
    "R[6]":"C04A6AD0",
    "R[7]":"00000060",
    "R[8]":"00000000",
    "R[9]":"00000000",
    "R[10]":"00000000",
    "R[11]":"00000000",
    "R[12]":"00000000",
    "R[13]":"000000A0",
    "R[14]":"02454380",
    "R[15]":"00250781",
    "cpsr":"00113C96"
    "ms_since_epoch":1531064498000,
    "system_version":"5.00",
    "backtrace":"
    Function Address: 0x0044A530
    Call Address at Function: 0x0044A5E0
    Function Address: 0x003EBD68
    Call Address at Function: 0x003EBF18
    Function Address: 0x0039EA14
    Call Address at Function: 0x0039EA8C
    Function Address: 0x0042535C
    Call Address at Function: 0x00425444
    Function Address: 0x00630EF8
    Call Address at Function: 0x00630FEA
    Function Address: 0x00507170
    Call Address at Function: 0x005071C2
    Function Address: 0x004FB2BC
    Call Address at Function: 0x004FB2D2
    Call Address at Function: 0x004FB2EC
    Function Address: 0x00631218
    Call Address at Function: 0x00631234
    Function Address: 0x00507478
    Call Address at Function: 0x005074D6
    Function Address: 0x00631BE8
    Call Address at Function: 0x00631F1E
    Function Address: 0x005F3574
    Call Address at Function: 0x005F35A6
    Function Address: 0x0038BF44
    Call Address at Function: 0x0038C3EC
    Function Address: 0x0038BBB0
    Call Address at Function: 0x0038BC68
    "Commit ID":"ff63577084c2716a238b73fc3338f834ba4ba7a3",
    "Time":"2018-7-8 8:41:38",
    "CDP_LOG":"A7479,1A7449,1A7479,475B01,1D627D,1FF345,48E515,48E515,203A95,1D7DBD,2DA2DD,362D99,203A95,203A95,1E9399,203A95,203A95,48E515,478D2D,1E9399,48E515,4829B1,48E515,203A95,48E515,203A95,48E515,203A95,48E515,203A95,48E515,203A95,1E93AD,203A95,1E93AD,203A95,1E93AD,203A95,1E93AD,203A95,48E515,203A95,1F8B55,203A95,203A95,203A95,362D99,2DA2DD,1D7DBD,203A95,17BFCD,203A95,17BFCD,203A95,48E515,203A95,1E93AD,203A95,48E515,203A95,1E93AD,203A95,1E9399,203A95,48E515,4829B1,48E515,17BFCD,1C126D,1C907D,23A839,1E93AD,23A839,1C907D,1C126D,48E515,4829B1,48E515,203A95,1E93AD,203A95,203A95,203A95,48E515,203A95,203A95,203A95,48E515,203A95,1E9399,203A95,1E9399,203A95,1E9399,203A95,1E9399,203A95,48E515,203A95,48E515,203A95,48E515,17BFCD,1D7E41,203A95,16494D,47C83D,2249A1,48534D,47EEA9,22DBDD,1D7E41,203A95,17BFCD,203A95,17BFCD,203A95,17BFCD,203A95,1C126D,203A95,17BFCD,203A95,17BFCD,203A95,1C126D,203A95,1F8B55,1F8B55,1F8B55,203A95,203A95,17C06D,1C126D,1B5B65,21BEB9,12A011,21BEB9,1B5B65,1C126D,17C06D,203A95,1D7CCD,362D99,2DA2DD,203A95,",
    "Task Name":"MMP main",
    "Saved SP":"021692B8",
    "Saved LR":"B1406300",
    "Saved PC":"0044A5E0",
    "R[0]":"6E5D8024",
    "R[1]":"C052C0D4",
    "R[2]":"C0AC15EC",
    "R[3]":"FFFFFFF0",
    "R[4]":"170DCE00",
    "R[5]":"B1406300",
    "R[6]":"00000000",
    "R[7]":"00000001",
    "R[8]":"00000054",
    "R[9]":"00000000",
    "R[10]":"00000000",
    "R[11]":"00000000",
    "R[12]":"00000000",
    "R[13]":"170DCE00",
    "R[14]":"021692B8",
    "R[15]":"B1406300",
    "cpsr":"0044A5E0"
    On my last 2 rides my Garmin has shut down during the ride.. it always happens when a segment starts/ends... But not on all segments :( It suck.. makes me sad.
    I havent had a single workout without several shutdowns since early may.That makes the unit so far very diasappointiing. I have followed the upgrade paht both through both the official versions and public betas.
    But as a top notch product with so many pro users on the market for almost a year i guess there is a stable firmware configuration and a subset of functions that at least can work. I can live witout beein connectted to my phone or strava. I can also live without my speed and cadence sensor. I can also live wihtout most advanced functions on he Edge 1030. What i hope for is a configuration that works approximately at same level as my old triatlon watch, the Garmin 920. My ideal situation right now is to get the 1030 to work with the Vector 3S pedals and my Garmin HRM Monitor. So far i have just upgraded firmware and not had time to do serious testing.
    Please give any advice, for instance a a firmware downgrade advice for firmware version that can be stable with a minimum setup. . Is there a recommended resetprocedure ?
    Thanks in advance:)
    PS: Has any of you returned the device due to this error?
    My setup: Edge 1030 running firmware 5.0 ,HRM-strap (from the Edge Bundle), Vector 3S, Garmin Cadence Sensor, Garmin Speed Sensor, Samsung A5 phone running Android 8.0
    Mine has started shutting down during the activity. Happened on mast last two rides. Working fine, then look down, and the unit is turned off. I'm running version 5.0 with an apple iphone X with the 10.4. Is there any advice about how to prevent this from happening?
    So, is the thinking that by disabling strava segments it will prevent this from occurring?
