3.97 - ascents still not fix properly.
- Fixed issue where the ascent remaining and ascent to next course point data field values did not match the total ascent for the course.
It took me 1 minute to know that it is still not fixed completely.
Yes, these 2 data field values now match total ascent for the cours, but ascent in cours sent to 1030 now not match ascent data from garmin connect by about 30 % !
Garmin, you repaired one but spoiled the second thing, as a result this 2 data fields still shows incorrect values.
It was repaired 3 months ago, now it does not work again.
aweatherall :
01-31-2018, 09:30 AM
The problem is with what Garmin Connect is sending to the Edge. Let me pass what I have found on to Garmin.
02-02-2018, 09:46 AM
Garmin contacted me and reported the issue is now fixed. I just tried it and it works.
Delete the courses with the wrong elevation data off your Edge and try re-sending them from Garmin Connect.
Garmin.
You create cours in garmin connect, then sent to 1030.
In 1030, in cours summary, ascent-descent data must match ascent-descent data from garmin connect, after 3.97 update it does not work again- you have to fix it.
Then keep what you repaired in 3.97 update- ascent data fields mast match data from cours summary.
Garmin, you are closer, but still not there.
https://forums.garmin.com/forum/into-sports/cycling/edge-1030-aa/1302849-courses-incorrect-height
    In 1030, in cours summary, ascent-descent data must match ascent-descent data from garmin connect, /QUOTE]
    I am not fully persuaded that it must be true. Both Edge and Connect have its own elevation data concerning your course. So when I prepare my course in any editor like Garmin connect, it shows me ascent - descent data according its elevation data. When I transfer the course to 1030 it counts its ascent-descent data according to the elevation data of its map. This way it works, at least I suppose.
  • Build 3.97 made a change to recompute the elevation gain/loss using its on-board algorithm rather than accepting the value that maybe passed over. It is using the elevation data supplied in the course file (it does not change that), but it s computing it's own gain/loss value. These new values are then stored in the course file on the Edge and are used to report "Ascent remaining" and "Ascent to next course point".
    But your explanations do not change facts.
    It just does not work.
    Examples:
    Course 1. 130km. ascent: in garmin connect 1561m, in 1030 2395 m
    Course 2. 90km. ascent: in garmin connect 945m, in 1030 1465 m
    Course 3. 60km. ascent: in garmin connect 1014m, in 1030 1327m
    Do you see the difference? 800m, 500m, 300m.
    It is not a few meters, but hundreds of meters.
    Which indications are correct ?
  • I’ m explaining why the values differ. The 1030 uses a different method from GC to determine what the gain/loss is when using the same data points.
    Without riding the course you cannot really say which method is correct. Only that they give different values.
    Garmin connect and edge 1030 are designed by the same company.
    Why they do not cooperate with each other ?
    if nobody knows which indications are true, what sense do these functions have?
    How to use them, how should they be useful, if you never know what they indicate?
    Next update and another big disappointment.
    Garmin, when will you fix this whole mess ?
    Should we all ask for a refund ?
    Update 4.0 is a regular copy of 0.37.
    What did not work, still does not work.
    Garmin.
    Copy of 3.97...
