Here’s the one I’ve been using for years and can wholeheartedly recommend for exactly that combo (1030 and VIRB 30).
I have been using this particular combination with no problem. The adapter you linked to is a GoPro to 1/4 turn adapter. So if your Virb has a go-pro mount on it, this adapter will allow to fix it to the…
Excellent question. I’d also like to know the answer
a look a like quarter-turn mount is delivered with the varia ut800 light no picture
but do not know for the virb
guess DCR has multiple images on the setup to go through
happy & safe sporting
I have been using this particular combination with no problem. The adapter you linked to is a GoPro to 1/4 turn adapter. So if your Virb has a go-pro mount on it, this adapter will allow to fix it to the Garmin Out-Front Mount you are referring to.
One review of the K-edge unit says that it's a little short to be able to reach the start/stop button that is now on the bottom edge of the 1030. Do you find that it's a problem? Close to the handlebar, but ok? I need this type of setup and the cheaper Amazon alternatives sound like their plastic mount inserts are not up to spec. Thanks!
It is not the most convenient solution but I find it not a problem. I have Kedge mounts on all my bikes. I don’t like the plastic ones
