SDHC card bigger than 8GB doesn’t recognises installed OSM maps
I installed on 16GB, 32GB and 64GB SDHC cards OSM-maps using the Garmin map installer. Opening the Garmin directory on the SD card, it shows the maps regularly installed. Switching now the device on and looking for this maps, so they are not shown in the map list however the Garmin maps stored already in the device memory are visible. By copying the OSM-map files from the SD card to the Garmin device memory, they are visible and can be used. Installing those maps using a 8 GB SDHC card, it works.
Is there a restriction to 8GB SD cards to read the OSM-maps from the SD card?
What could be the reason for such a behavior?
Sommerflieger
