Anyone else had trouble with their 1030 shutting down while charging?? I plugged mine in tonight and it charged fine from 30% to around 80%, then it would just shut off. It wouldn’t let me do anything with it until I unplug and plug back in. Then it will charge for 10 or so minutes, and shut off again. Between 80% to 100% I had to unplug and restart prolly 6 times... I’ve swapped wall outlets and charging cubes and same results:/
Update. It didn’t have anything to do with the 1030 charging. It was shutting down multiple times after I finished charging also. Is anyone else still having trouble with shutdowns?? I’ve had my 1030 since last October, and it has been practically flawless until tonight. It has shut down on me tonight at least 20 times in the span of a couple hours...
If that problem came "out of the blue", I suggest to delete (save on PC) all activity-fit-files. Maybe one of them is corrupted. If that's of no help, a "hard reset" should be performed.
Edit; first of all you can try if shutdowns also happen, if you disconnect the phone and keep it disconnected.
