Hi,
I?ve got a problem with wheel size in the 1030 speed sensor.
I use a spinning bike and in the edge 1000 I configured manually de wheel size but in the 1030 the max size is set to 3000mm and with that size de speed (and the distance) is about half that should be. In the Edge 1000 with 1550mm more or less the speed and distance are correct, but in the 1030 far from that it?s about 25% the real value.
Can the 3000 limit value be override somehow?
Thanks...
