I did a cardio workout which will not sync to connect. When I view the workout on the watch in history this is what I see. This is my 2nd watch after returning one due to the mid session crashing fault discussed elsewhere
2021-01-08-15-03-58.zip Ok see if this is better. I have just done another cardio and it happened again. Exactly the same screen on the watch as before. I have put both activity files in the folder
You can Upload Manually to Garmin Connect Web but there is only Heart Rate Data in the Files. It will come up as a Run but You can Change it.
Fixed With Golden Cheetah. Why the Watch is doing that I don't have a clue.
It Recorded all the Heart Rate Data but it did not finish the Job.
You could try a reset on the watch.
www8.garmin.com/.../GUID-6742ACA9-80F0-4460-B4ED-D68056741A23.html
