Would it be possible to have a low battery warning, like many other garming devices?
I doubt that it will be of any use in case of GS2: every face shows the battery level, the battery level readings have a granularity of 20%, the battery lasts 3-5d (depending on usage).
Whenever you start a workout and your battery level is 40% (at the beginning), you should charge the GS2 after the workout. This is the best low battery warning you can have.
IMO GS2 has more serious issues then a missing low battery warning.
