Hi,
my watch is stuck on miles on the watch, on the phone it is in KM which is what I want. I can not find any way to correct this, anyone have any ideas?
Hi,
Same here. Changing it from 'metric' to 'statute' and back to 'metric' again looks to fix the problem. Hold UP, go down to settings -> system -> units. I had this happen before…
I have changed a couple of times, from km to miles and back again to km and afterwards synchronized with Garmin Connect (with everything with km). It solved the problem.
Did you try this? Changing the Units of Measure
Hi. I have the same issue. I set my setting in Km both on the watch and on the Connect app but the watch shows in the data fields pace and distance in miles (strangely while I am running it keeps track of my time per km, showing it every km)! Help please!
					Hi, I think I found out what the problem is. Since this is a Swimwatch and you run with it you must change units under swim in settings, not only general units. Strange but it worked for me! You will then get a swim symbol and measured in km on the left of the display!
Thanks but my display is already showing the swim data in meters/km...
Same here. Changing it from 'metric' to 'statute' and back to 'metric' again looks to fix the problem. Hold UP, go down to settings -> system -> units. I had this happen before, after an update, my clock changed from 24h to 12h.
Worked for me too on a Forerunner 55
