Stop drill log
Today I noticed a bug that I can't stop drill log mode. When I pressed Lap/Back button to finish drill (per instruction on the watch) nothing happened. I had to stop training session (pressing start/stop) and only after that watch suggested to choose distance I swim in the drill.
It doesn't happen always, but this happened to me already 2 times. The button itself is working.
Thanks
  • Did you use auto rest function with Stop/resume session? That can cause such issue. Right now pausing the session should be done ONLY by lap button.
    0 Former Member in reply to PG
    I’m using auto rest function. During swimming session I start drill log and can’t exit it with Lap button.
    My swim 2 is stuck in drill mode.  No amount of button pushing will change it to some other mode.  I can't even turn it off.  HELP!
  • Push "light" button (upper left) for about 15 sec, this should shut down the watch. However I can not guarantee how it will wake up afterwards, in case you experienced a real bug.
    What SW version are you on?
    Thanks.  I did this and it seems to have worked.   I hope I don't end up there again!  I don't know what SW is.  If did, how would I find out what SW version I am on?
  • SW stands for software. You can check it by menu item "About". The first screen shows the Unit ID and software version.
    However I am aware of problems with drill log only with the first released software 2.10 when combined with auto rest function.
    Thanks. Sorry to be so uninformed, but can't see any item on the watch or in Garmin connect which called "about".  Can you be more specific?
  • on the watch, long push "up", you get into the menu list. Scroll until you get the item "about". Push "start/stop", and you get the first screen telling the software version.
    on GC app, watching any activity recorded by the watch, below the watch icon you can see the software version
    on GC web, if you click on the watch, it displays all of the information
    Thanks.  Version 2.4.  I found this on the watch. Couldn't see it below the watch icon on the app.
  • I am not aware of such bug in 2.40. In case you experience it again, please report it to garmin support
