Hello,
I noticed an issue with the wrist HR not being broadcasted while cycling right after running with a HRM 600 (same behavior on 965+HRM Pro).
How to reproduce this issue:
1. Run with HRM 600
2. After running, remove the HRM 600, put it into the running bag
3. Go cycling with the bag on the back and try to broadcast the wrist heartrate to the Edge computer.
> no HR will be transmitted; watch also does not show any HR on the broadcast screen
Expected behavior:
if HRM 600 is not worn, the broadcast should send the wrist HR.
Workaround:
1. Don't bring the HRM600 (not an option when going back home after a run training)
2. Disable the HRM600 connection, the wrist HR will be send properly. However, it is quite annoying to enable/disable the HRM connection each time I want to broadcast
If I am cycling before using the HRM 600, the broadcasting works fine.
This issue only appear if I have been using the HRM 600 soon before.
