Altering alarms with voice command
I'm able to set a timer or wake up call using a voice command but do not seem to be able to edit or cancel them the same way. I have to use the buttons and select clock/alarms. It's not a big problem but if Garmin has gone to the trouble of adding a voice command system to set up alarms it should be easy to add edit/cancel commands.
