Hi, Garmin introduced an outer distance ring on maps while ago and I've never seen ability to turn it off on other Forerunners.
I wonder is that still the case for 970 that you always see a distance/range ring with north up and without navigation direction data field?
In track up it's not a full ring and only at the top, but then the map moves a bit around. And with active navigation data field on the map screen, I believe it doesn't show either, but if you just want to show as much of the map possible with track only, I didn't see a way to turn the ring off on any recent Garmin watches.
Thanks!
