Course navigation UI
In the 955, when course navigation is added to an activity, additional data screens appear behind the configured ones showing things like course completion %. why have these disappeared on the 970? is there a way to bring them back that I'm missing?
  • Idk if this is what you're searching for, but there are additional information (even a data+map split).
    You load a route, start the activity, swipe right or hold UP and select the route again. In my case there appears a split screen with map, timer, remaining distance and ETA (and some additional route-specific datasites.
    Now if you swipe right and left or hold UP, you're back in your preconfigured datasites in addition to the navigation ones.
    No clue why this is so hidden
  • oh gosh thanks for this. basically, you have confirmed a bug exists. one has to start the activity first then select course navigation to enable the extra screens. this should not be the case. enabling course navigation should be done BEFORE the activity is started. also, these extra screens have to be manually added still - they were automatically added in the 955 era.
    please confirm a bug report exists for this
