FR970 Charger Not Working
I’ve charged several times so far without issue, but this morning the charger snapped into place but didn’t register it was charging. Different USB-C port didn’t help.  I tried disconnecting/reconnecting from the watch and wall several times also didn’t help.  Wiggling the connector on the watch side a few times worked then stopped charging.  Eventually I got it to a sweet spot where it charged.  I didn’t see anyone else report this issue, so maybe my watch or charger has an issue?
  • The cable is probably at fault.
    The watch is too new to have any problems with the contacts.
  • Following up on this, the charger started working again and hasn’t had an issue the past few weeks.  Maybe was a firmware detection bug?  Or maybe a reboot fixed it?
  • I am having this issue now - FR970 is not charing.  I purchased it new 2 months ago and typically charge it one each week,  This week the watch did not charge,.  I've cleaned the contact points, tried a different cable, tried a restart several times, different charging ports on my computer, tried a portable power pack, tried plugging it into the wall, tried wiggling the cable, and nothing has made a difference.  I still have several days battery life left, but will soon be really needing to charge it.  Suggestions?
  • No idea, since mine self corrected.  I also swapped to a cable with a right-angle connector at the watch end.  $9 off Amazon for a 2-pack and has been SO much better than the stock straight cable and allows seeing the watch face and not sitting the watch on its face to charge.
