waarschuwingsignaal trillen instellen
Is het mogelijk om het trillings waarschuwingssignaal in te stellen naar sterkte
  • Translated:  Is it possible to adjust the intenaity of the vibration warning signal?
    (It helps a lot if you post in English)
    I am still not sure which warning signal you mean (the same aa in your previous post I guess). Maybe using audio alerts on your phone could solve your issue, you can adjust the volume of the phone.
