Wifi connection fails
Hi,
i am using die PlayRun-App vom connect iq to sync my Podcasts. It worked really well. But since a few weeks I got issues.
When I start syncing, the watch tries to connect via wifi, but then appears the message "Übertragung fehlgeschlagen". I think "transfer failed" is the right translation. A restart of the watch helps to sync one time. But next time it's the same problem again.
Has anyone a solution for me?
Thank you very much!
Markus
  • Hello!
    We have seen where sometimes that can be a concern with the router you have not meeting our requirements. Of course we have some other troubleshooting tips here: Troubleshooting Wi-Fi on a Fitness Device
    Most importantly though, it is the requirements:
    • Supported Frequency: 2.4 GHz only
    • Supported Protocols: 802.11 ac, b, g or n (802.1x is not supported)
    • Supported Channels: Channels 1-11 only
    • Security: Unencrypted,  WPA, and WPA2
    • Passwords for encrypted networks must meet an 8 character minimum in length
    • Networks with a hidden SSID are not supported
    Make sure your router meets all of those, "transfer failed" messages can come from the security point or channels! If those are all set appropriately, I would be happy to follow up with you on email if I have permission from you?
  • Hello Hannah,
    thank you for your answer. Sure it is ok to follow up on email.
