All day and on demand are working.Therefore also no Breathing Variations available in Sleep analysis in Connect.
Hi Osc_ar,
Do I have permission to view your account to see sleep data and other settings?
Can you confirm on your watch that Pulse ox is enabled all day?
If you go to the sleep widget specifically, can you see breathing variations and pulse ox on the sleep graph if you filter those features out?
Viewing Sleep Statistics and Details in Garmin Connect - scroll down to find the section of the sleep stats and the features you can click on to see each one. If you click on them and they are blank with no data, let me know!
Is this data also not showing on your watch or is this only a Garmin Connect concern with no data showing?
Thanks Garmin-Hannah for responding.
Yes, All-Day mode was enabled.
Therefore, I performed some additional troubleshooting.
Turns out that the setting was conflicting with the Battery Saver option to turn of Pulse Oximeter. The Batter Saver itself was configured to turn be turned on in Sleep Mode. After I changed this, it started working as expected.
It does make sense, however, a mistake is easily made, so maybe that can be improved in the UI somehow?
That was my next ask! Battery Savor mode being turned on can turn off additional settings/features on the watch. Glad you found that to be the case! That feature is not on by default. Just a setting check if one did turn it on at some point.
PulsOx and sleep stress data can simply disappear. Not always, but sometimes with the same settings without power saving mode.
For example, if you go to sleep later, this is an unsolvable problem for this device.
Garmin is not able to implement fundamental features reliably, not even after 10 years and I don't think they ever will.
