Our daughter race walks two laps on an 400m track, and the watch typically records her distance as over 1000m
I've been in contact with support who suggested making sure the GPS has enough time to 'soak in' prior to the event. We've been putting the watch in a ready mode at leat 10 minutes prior to her actually starting her race walk.
The track run mode 'forces' the track into an oval shape, so any extra distance gets 'squished' into an oval and it's not obvious whether the initial track was way off to begin with.
The watch is set for 200m laps and properly beeps at those distances. So the GPS seems to track properly, but the internal accelerometer seems to not be counting her arm swings properly, and the data obtained via the accelerometer is what seems to be messing up the data. You'd think that the GPS track would be programmed to have priority over the accelerometer if they disagree with each other.
Anyone else have this problem? Getting really close to forcing a warranty refund on this watch after 5 tech support calls and Garmin not being able to figure it out. Thanks.
