Everytime i recharge my watch then go out for a run the data screens change after a while to strava settings. This is annoying as i specifically set the screens up to see the data i want.
Starva screen? Is it a segment?
Normally it comes up when you cross a segment if you have that enabled?
I have two run activities set up (well 4 actually with different settings) , one with Strava segments ON and one with them OFF so when I'm not interested in segments I choose that one .
Easy to do.
So you say that in the Activity Settings, Segment Alerts are off?
I'm also not sure what you meant by "strava settings" apart from the screen that shows the segments?
Have you tried to reset the activity itself via restore defaults on teh activity and then set it up again
