bug: no way to add Temperature to the layout of Ice Skating activity
There's no way to add temperature fields to the Ice Skating activity's layout.
To reproduce:
1. add Ice Skating activity to your ft965
2. go to Outdoor
3. ...
4. Ice Skating Settings
5. Data Screens
6. Chose the 1st layout (HR, Time, Active calories)
7. Data Fields
8. Chose Active calories
9. Up/Down
You'll see that the Temperature section is missing, and the Temperature/Max Temp for 24h/Mint temp for 24h fields are not even under Other section
    This must be a bug, because there is a setting in the Ice Skating activity "Record Temperature" that is On when a Tempe is nearby. If it is recorded, it should be possible to have it on a data screen.
  • Reported today to customer support. Let's see in how many quarters they'll fix it (not that I'll have a chance to really use it, I came back today from frosty Europe, but I'll try in the indoors ice skate)
  • According to Garmin "This has been fixed with the 22.22 software update"
  • Indeed it works now. And this was fixed in less than a month from reporting to being published as production! Wow! I'm impressed! I realize it's a bit of luck with the timing of the bug discovery related to the release cycle, but still it's very nice, Garmin! I hope this fast response time will continue to be the new standard :) And also thank you for notifying me in email in the ticket I opened!
