I have been having issues with wrist hr. It used to work great until a few months ago.
Right now it's hopeless. Be it if I train outdoors or on the treadmill.
Is there a wider issue or is it potentially just mine.
Who would have thought it. Restarted and it worked great.
It did update yesterday as well so maybe that helped.
Garvin says restart once a week so will try that going forward.
You are not the only one.
See here just one of the threads on the issue: https://forums.garmin.com/sports-fitness/running-multisport/f/forerunner-965/386942/forerunner-965-hr-issues-after-update-20-29#pifragment…
Same problem here, during easy training on a treadmill or indoor cycling it shows 204 HR for 1 hour for example, after which it shows 90+ hours of recovery even though in reality training was easy... Not…
See here just one of the threads on the issue: https://forums.garmin.com/sports-fitness/running-multisport/f/forerunner-965/386942/forerunner-965-hr-issues-after-update-20-29#pifragment-1279=2
Garmin keeps closing the threads and ignoring the issue.
Same problem here, during easy training on a treadmill or indoor cycling it shows 204 HR for 1 hour for example, after which it shows 90+ hours of recovery even though in reality training was easy... Not really what I would expect from Garmin. I borrowed watch of my partner and it was actually working fine (even though it was more of fashion watch)
Occasionally during the exercise suddenly the heartrate drops to about half, and after a while (like 10 - 30 minutes) it returns to the right value again. The result is that all parameters calculated using the heart rate as input are useless. I have this problem ever since I got the 965. Is it a software bug, or is my watch broken? I always have it firmly strapped to my wrist.
Yes, it' a bug and one common to other (all?) Garmin models, including my Epix Gen 2. I decided to ask ChatGPT about it. Here is part of its response, comparing Garmin watches to other brands.
For now, Garmin users experiencing these issues often rely on external chest straps or arm bands for consistent heart rate monitoring. If you're still encountering these problems despite following best practices, it might be worth raising the issue directly with Garmin support for a detailed response or workaround.
