How to make swimming workouts intervals auto-lap?
Hi everyone,
I use my FR 965 for swimming and I have some sessions where I basically do benchmarks and plan to hold different speed at different intervals all in consecutive swim.
So for example I want to do 800m so I create this workout, all intervals are using the Garmin target pace feature so I know when I should be hitting the wall and therefore if I'm running ahead or behind :
- 1st Main set is 200m at 1:40
- 2nd Main set is 400m at 1:45
- 3rd Main set is 200m at 1:35
As you can see I haven't put any rest in between because I want to do continuous 800m without stopping and I wish the watch would just move to the next phase once I hit the wall (for example after the first 200m and then after 400m).
The problem is that the watch stops after each interval. Even if I haven't put any rest intervals in between, the only way I see to fix this problem is putting 1s rest between each set even if I'm not stopping at least that way I wont have to stop swimming and press the lap button?
Anyone else having this problem?
