Today 11.000 calories (9k+ resting).
Hi,
This morning I was doing a workout and right after that I received the 20.32 update. At the moment (19:00 local time) u burned about 11.000 calories which is abnormal. Both the active AND the resting calories are high:
  • active: 1800 (which is high for my 1 hour workout)
  • resting: 9300
Heartrate seems to be correct and also my RHR seems fine.
Could there be a relation to the update (although the release notes doesn't mention such updates/fixes/..).
Regards,
Bart
  • Have you checked how your weight is set in the watch?
  • oh wow, you are great.... the weight is on multiple places defined and the one on my device is 865kg.
    I did change the weight just before workout and the update. I did it using the Connect website where I and used a . instead of a , for 85,6kg. I changed it back right after and it was updated correct on my general profile but apparently not on my watch. That is weird but sorted out now.
    Thanks!
