Since loading 20.32, my nap detection has not been working. It has not detected one nap since.
Historically it has worked really well for me, across all the FW since it was introduced.
Any thoughts, as the changes with 20.32 shouldn't affect this.
also if I set sleep mode manually during the day, it doesn't measure sleep
when I have sleep set from 10:00 p.m. to 7:00 a.m. and I'm on the night shift, after turning on sleep, I turn it off manually, then it switches back to sleep mode for a while. How does it work for you?
My sleep detection works OK. But if I want to turn the sleep off in the middle of the night (say) i find that the best is to go to a widget , thats shows "sleeping" on it and then open it and cancel sleep. It seems to be different doing that than sleep mode (from say control wheel) which seems to be a set of watch settings during sleep rather than activating sleep itself if you understand my convoluted sentence
That is how I understand it as well.
With that said, my nap tracking is still flawless in 20.32, so I've got no suggestions for you :-(
It decided to work this afternoon and recorded a Nap! Maybe the fact I altered slightly my sleep schedule yesterday tricked it into starting again!
Here is hoping!
Had issues with sleep measurement after updating to 20.32. Looks like restarting it solved it. I also noticed that when I manually change the sleep mode, the watch goes back to the previous setting after a few minutes. This issue was solved before, but now it is coming back.
How is that working for you now ?
Just got an FR965 and ZERO naps recorded...took a long one this morning after working overnight and only dozing off from time to time. Actually that confused the FR965 that thinks I haven't slept for two days !
I've had no naps detected since 21.19 on my FR165...could have been an earlier up that broke it as well, but it was very good at detecting naps previously. They introduced a regression and have yet to acknowledge
My Watch on 21.20 is not detecting naps either. I don’t get as many nap detection test opportunities so I’m unsure how long this has been a problem.
I like Garmin, but this has been such a buggy platform.
