Bugs or features?
Hello together, I have noticed following Issues after the last firmware update:
  • by sleeping was tracked 300 steps, which were again "deleted" after getting up
  • the fitness level show a higer level even by 52,45 - maybe is now a second decimal used?
  • hare rate is messed even on the tabel, but this issue I konw since forerunner 935 :-)
  • Garmin accepted my bug - no vibrations by breath activity with active DND mode. it was corrected only from the half - it vibrates only by breath in and out, by pause not (did someone test the solution before rollout? :-))
  • and my biggest question: by activity, if the light button will be doppelclicked, flaschlight goes on, than doppelclick aggain and flashligh goes off. After this will the display stays 2 minutes active. This ist pretty nice feature by activity. But wenn will be the activity paused, this behavior stays - atfer every touch or button click, lights the display 2 minutes. Can consume a lot of battery, if you didn´t check it. Is this really a feature or bug?
Maybe some developer from Garmin will read this a give some reply. I tried to report all of this trough support, I senden even video, but somehow no reaction :-(
