1. Please enable sleep mode on/off.
2. I usually use battery saver mode. Turn off the heart rate.
-> When it is time to sleep, the heart rate is turned off and sleep cannot be measured. -> However, because sleep mode cannot be turned off, the gesture function is turned off.
3. Forced use of the damn sleep mode causes a conflict with the battery saver mode.
4. Occasionally, if you exit the battery saver mode to measure sleep, you must turn on the battery saver again in the morning.
5. This process is too cumbersome.
6. Add battery saver mode to the shortcut key.
