User profile / Frequency and power zones / Heart rate
I practice running and cycling, what is the best way to configure this? I have %RHR in general and lactate threshold for the race, can I have, for example, % lactate threshold in general? How do you adjust it?
Another thing that bothers me about this is that it is not updated only when there are changes in some training, for example the maximum frequency or the threshold frequency changes, or even the rest frequency, you have to enter User profile / Frequency and power zones / Heart rate and here manually adjust the new values.
Top Replies
  • I practice running and cycling, what is the best way to configure this?
    Unless you are a serious competitive athlete or you have a coach customizing your zones and training regimen based on…
All Replies
    Unless you are a serious competitive athlete or you have a coach customizing your zones and training regimen based on lab tests, don't bother about creating different sports heart rate zones. Using a single zone system with the Garmin defaults percentages is plenty good enough to target various physiological benefits.
    You can use any zone system. If...
    - your Max HR is correct,
    - you wear a chest strap during activities for accurate HR data,
    - you wear the watch during sleep for an accurate Rest HR,
    - you have a balanced training program
    - you have completed the built-in threshold tests,
     then the different zone systems will be very similar.
    For Rest HR, you have the option to select "use average". Do this.
    For Max HR, use auto-detection and run a variety of efforts. You don't need intense efforts to get a new Max HR detected. If the auto-detections vary by only 1 bpm, you can turn it off for a year or so.
    Max HR auto-detection will automatically adjust your Max HR value in the zone definition. After a Max HR auto-detection, perform a built-in LTHR running test.
    LTHR auto-detection doesn't work very well unless you perform a lactate threshold like test (maximum steady effort for at least 30mn). Otherwise, auto LTHR detection might give you a wrong LTHR and pace.
    However, the build-in test works well, because it is calibrated as a steady ramp. Do it and repeat it whenever you change your Max HR as Max HR influences the detection.
    If you get a new LTHR after a test, it will be updated in the zones. After an auto-detection, you can accept or reject it.
    Whenever you have a new Max HR or LTHR, I recommend you go to your zones and reset them. Many users including mysefl have reported a change in the zone % after a new detection. Resetting the zones to their default is highly recommended.
