Hello
using my Forerunner 965 since several months, I face some elevation issues (and also altitude issues) since a few weeks (probably since end of February / beginning of March)
Main issue : elevation gain calculated is very overrated.
Last experience : yesterday training around 12,6km run
- Garmin elevation at the end of the run : +535m
- Strava elevation corection : +306m
- Garmin elevation after adjustment with Garmin Connect : +354m
- Comparison with friends who did the same run : real elevation seems to be around 320 / 350m (COROS + others Garmin)
I know there are still some elevation differences between Strava and Garmin due to different DEM. Also well aware about GPS precision which can affect elevation calculation (even if barometric alimeter must be able to adjust this issue). But clearly, for this run elevation gain is overrated with my Forerunner 965.
For infomation, I recently made a reset + full cleaning of the watch including sensor. I use last beta version software (19.09). Altitude calibration is set on AUTO after each run
My issue is also not always repetable : last Sunday, trail run of 19,2km : Garmin elevation +1150 / Strava +1190. So very good and also realistic by experience as I alreday did several time similar run
Base on this experiences and also after reading some others posts, I don't think my sensor is broken. I suspect more an issue with the software or the algorithme, especially with the temperature sensor.
Does someboby have similar issues and analysis or feedback ?
