In altitude History the altitude Curve do not match with the displayed time. I climbed this morning at 8:00 and now it displayed the corresponding climbing yesterday.
If you're experiencing a bug where the altitude curve in the history doesn't match the displayed time, there could be a few potential reasons for this issue. Here are some troubleshooting steps you can try:
1. Check time settings: Ensure that the time settings on your device or application are correct. Sometimes, if the time zone or clock settings are incorrect, it can lead to discrepancies in displayed timestamps.
2. Refresh or reload: Try refreshing or reloading the altitude history page. It's possible that there was a temporary glitch or error in loading the correct data, and a refresh might resolve the issue.
3. Clear cache: Clear the cache of the application or device you're using to view the altitude history. Cached data can sometimes cause inconsistencies in displayed information.
4. Update software: Make sure that you're using the latest version of the software or app. Developers often release updates to fix bugs and improve performance, so updating might address the issue.
5. Contact support: If the problem persists, reach out to the support team or community forums for the specific device or application you're using. They may be aware of the issue and have troubleshooting steps or a fix available.
6. Check GPS and altitude data: Verify that the GPS and altitude data being recorded by your device or application are accurate. Inaccurate data could lead to discrepancies in the displayed altitude history.
7. Report the bug: If none of the above steps resolve the issue, consider reporting the bug to the developers or manufacturers of the software or device. Provide details about the problem you're experiencing, including any steps to reproduce it, so they can investigate and address the issue in a future update.
By following these troubleshooting steps and potentially reaching out to support or reporting the bug, you can work towards resolving the altitude display issue in your history.
