Calendar not synching correctly
I have noticed that when trying to sychronise the watch the previous workouts still remain in the scheduled excersises and therefore there is a message saying that it's full and cannot add new excersises in the calendar of the watch
So far the excersises from previous days were deleted and the excersises of the following days were added. But this doesn't work anymore and also there is no way to delete the previous excersises from the watch in order to create space for the new excersises.
I am not sure but I think that this happened after the latest update
  • Are you building your workouts in Garmin Connect and adding them to your calendar, or use a different source of workouts or scheduling?
    If you go to Start Activity > Workouts > My Workouts, then do you see a lot of workouts there? After selecting a workout, can you delete it with Start Activity > Delete? I suspect that previously scheduled workouts might have accumulated and hit a limit. You might need to clean some old workouts you no longer need.
  • Thank you very much for your reply. I really appreciate it
    As you mentioned I have built the workouts and have saved them in Garmin Connect. I add them to calendar in Garmin Connect and then they are synched to the watch. Later  after a workout is done or the day passes usually the previously scheduled workouts are being removed automatically from the watch and remain just in the calendar of garmin connect and the new workours are added for example for the following couple of weeks. But this seems not to work appropriately latetely.
    It has nothng to do with my saved workouts in the watch because as far as i know you can save a number of workouts in the watch. This is about the calendar and the synching
    Also there is no way to remove or delete scheduled workouts from the calendar in the watch in order to make space and as far as they are not removed automatically there is no space to sync the following workouts
  • I'm also experiencing the same problem. I have a training plan from my coach, it's auto populated to the watch. When I added a half marathon date the watch build a plan itself, which I didn't request. I'm looking forward to hear something from this bug or at least how to delete the entire garmin watch plan...
  • I am having this issue now. Did you ever resolve it?
  • It seems to work fine now. In fact it is fixed long time ago. Unfortunately i don't remember at all how i had overcome this problem. If something comes to my mind or i remember anything i will return to assist you. I apologise
